How to change ini file on RT with RT application
Is there any way to change the custom ini file on RT with RT application?
Now I am doing it by ftp it to host and change it and then ftp it back.
Thanks a lot for any input.
Anne
(4,767 Views)
Files on the RT device can be accessed just like files on your hard drive.
Why not read it (using the file I/O VIs), change the text and write back?
___________________
Try to take over the world!
(4,761 Views)
Not really.
Ini file on RT seems only readable. I tried to use Configuration File vi to change them, but it didn't work. The program run OK and didn't give any error, but the ini file didn't change at all.
(4,758 Views)
Did you try overwriting it explicitly (COPY another file in its place)?
I don't have any RT devices near me, so I can't test this myself.
Is this INI files or general or specifically the files used for the app?
___________________
(4,755 Views)
