annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
How to change color of blinking LED
in the attached file is a LED with property blinking = true.
The problem is that it blinks yellow.. How can i change the yellow to another color?
TFTC
Messaggio 1 di 9
13.009Visualizzazioni
I would create two led one yellow and the other is already create
use property node to ger the color cluster(for the value of yellow
keep thoses clusters and swith them for the proper color of the led
in the property node
Messaggio 2 di 9
12.996Visualizzazioni
hi!
   In the KnowledgeBase I've found this, that should be right for you.
   However, it's not good, to my opinion, that you cannot programmatically change blinking color.  I suggest, if applicable, to manually change the ON color, instead of setting blink to TRUE. This takes longer to do, but you can control it programmatically.
   I hope this helps!
   Buone Vacanze!!!
graziano
Messaggio 3 di 9
Hi jjcimon,
   I'm not sure to have correctly understood... can you explain, or post an example (for LV 7.1)? Thanks!
graziano
Messaggio 4 di 9
12.993Visualizzazioni
If you go into the labview options, and select colors.  There is a color for the blink foreground and for the blink background.  Changing these from the defaults will add these entries to you labview.ini file.
blinkFG=
blinkBG=
If you make an exe from your VI you will need to add these two entries to you exe INI file.  You can also change the speed.  On the upside, you can do this programatically, but it will require a restart of the VI in order to re-read the INI file.. I think, I have not tested it... but I assume that it is only read on launch.  You can experiment with it.
You can also change the blinking speed in the properties which adds the line
blinkSpeed=
I hope this clarifies things
Paul
Messaggio 5 di 9
12.980Visualizzazioni
I was too sure I did change that color before,   because I am using blinking led
I just went to try all of this and realize the yellow blinking color
is not part of the property ........
sorry that was not the answer, I will try before posted
Messaggio 6 di 9
12.976Visualizzazioni
Hello Stradis,
i already know this option, but this is for all LEDs what i ever create. I want to change the blinking color of only one LED the rest should stay in default.
Messaggio 7 di 9
12.973Visualizzazioni
It is a limitation, if you want to change just one boolean led, you will have to manual switch the state, t/f.  It is not a property of the boolean.  Sorry
Paul
Messaggio 8 di 9
12.971Visualizzazioni
How about this?
Note - this was just an example. It is by no means a finalized tool, although it should work for your LED with no problem.
___________________
Try to take over the world!
Messaggio 9 di 9
12.929Visualizzazioni
