How to change an event in Event structure Automatically?
      I want to change an event automatically when a boolean value change occurs.I tried with a blinking LED but it didn't work.Can any one help?
(3,485 Views)
Accepted by topic author $agar
Value Change Event can be generated either from Front Panel User Action or Value (Signaling) Property.
TailOfGon
Certified LabVIEW Architect 2013
(3,473 Views)
You'll need to use a Property node for this as well as shown below:
Right click on the Add indicator >> Create >> Property Node >> (Value Signaling). The use of this property node is to set the value of the control and generates a Value Change Event.
More info as below:
Hope it helps.
Warmest regards,
Lennard.C
Learning new things everyday...
(3,468 Views)
Thank You
(3,462 Views)
Just to warn you, the Value Change (signaling) property will cause the event to be fired, even if the value did not change.  So you really should have some logic to figure out if it actually changed.
(3,433 Views)
