How to change a 1D array data to a string with a tab or space between every two data?
How to change a 1D array to a string with a tab or space between every two data? I tried with while loop, and for loop, but failed.
(3,325 Views)
No loop needed. SImply use "array to spreadsheet string" and wire the desired delimiter.
(3,321 Views)
Did you get it to work?
Here's what I had in mind. 🙂
Message Edited by altenbach on 06-03-2007 06:52 PM
(3,306 Views)
In Altenbach's attached picture, if you leave the delimiter unwired, it ll automatically take the default Tab delimiter. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,291 Views)
It is just what I need.
Thanks altenbach and partha.
Jing
(3,280 Views)
I used a comma in the example picture because its more visible in a code image. Of course you can use any delimiter you want, even multiple characters or non-printable characters.  Sometimes it is easier to set the delimiter constant to '\'-codes display.
(3,259 Views)
