How to change Context Help at Runtime ?
Hello All,
I need small information. Please help me.
Is there is any way to change the context help at Runtime?
Actually I want to display Context Help based on OS Language.
Munna
(4,122 Views)
Hi Munna,
you can change the tip strip with a property node, but you can't change the context help for a control.
I tend to use a different scheme:
Detect mouse enter/leave events for each control of interest. Display a text based on the reference of the control under the mouse in a string indicator. Now you can change the displayed strings depending on language settings…
(4,118 Views)
Hi GerdW,
Thanks for your Idea. It’s working nice.
Actually it’s quite uneasy if no of Indicators/controllers are more.
If NI will provide property node for Context Help  then it’s more useful.
Munna
(4,100 Views)
Hi Munna,
what's uneasy?
You can get all control references at once using a property of the VI/panel. Then you just select/filter text by control name…
(4,081 Views)
Hi GerdW,
Thanks for your help.
I can read all control values at once but I’m not getting how to display Help window for that particular control (By Event).
Like this I can get, But as I told in my previous post, Event cases will increase based on No. of controller/indicators (please correct me if I’m wrong).
And other issue, at Runtime we can change context help window size/position but what about Help Text indicator (which we are talking)?
May be we can do workaround like, displaying another VI (looks like context Help window) & sync up with Event/custom menu.
Munna
(4,057 Views)
Hi Munna,
- you can create user events for your controls, so the event structure reduces to just one ( or two) event cases for that help.
- you can create a case structure with a case for each control outputting the help text for that control. (Or use a lookup table approach.)
- you can create an additional window using a subVI. You can make user interfaces with autoscaling options in LabVIEW to mimic that help window.
You can do all this. You have to program it using opportunities found in LabVIEW…
(4,029 Views)
Hi GerdW,
Munna
(4,018 Views)
