How to change Agilent scope termination setup from 1M to 50ohm
I am using Agilent MSO8104A scope and have this prewritten labview code. I think it shares agilent 5483 driver code. Now wants to change 1M termination to be 50ohm. Where shall I start? Which subVI shall I look for or change? Thx.
(2,786 Views)
Go to Help and turn on context help. Open the Tree VI or just browse the functions in the driver. It really should not take you more than a couple of minutes to find the correct function. And, if I may be so bold to say it, you can use the scope manual to find the SCPI command. Use the text search tool in LabVIEW to find where it is used.
(2,764 Views)
