How to call looping-vi twice?
i have a sub-vi that is looping on a comport until it receives a special-character (\r\n) then the loop stops.
Now i need to execute this vi twice at the same time. Currently i just copied and renamed it - this is working.
But is there also another way so that i only have one vi?
Thanks for help
(2,694 Views)
You can make the VI re-entrant. Be aware that this has its own caveats. If they're sharing hardware, then this won't do you any good, for instance.
You can read about re-entrancy in the LabVIEW Help.
(2,691 Views)
Parallel For Loop?
Richard
(2,677 Views)
A parallel for loop would not allow the second instance to run until the call to the first instance of the VI is finished.
(2,662 Views)
Thanks smerc. Sorry OP for the off-topic.
Richard
(2,649 Views)
