How to calculate the height of an object in a picture
How to calculate the height of an object in a picture (pixel)
(3,742 Views)
What defines an "object"? Can you show an example picture?
(3,731 Views)
like this,i want to calculate the height of the green one object.how can i do?
thanks
(3,719 Views)
If you want to calculate the object dimensions in terms of pixels, use Particle Analysis: Particle Analysis will give multiple parameters just check them:
https://zone.ni.com/reference/en-XX/help/370281AC-01/nivisionconcepts/particle_measurements/
-If you want the real world dimensions then you have to use Calibration and apply on to the original image/pixel dimensions.
uday
(3,691 Views)
No doubt, you already knew that number of pixels will tell the height (obviously in pixels) of the object. But at the same time you also want to capture a ruler placed at same depth (of field) as the object is so that you can determine how much each pixel, in the image, corresponds to a given engineering unit of length.
You might also be interested to check machine vision library.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,687 Views)
