How to burst pattern onto DUT using Labview
I've made a pattern to burst onto a DUT and have been doing so using Digital pattern editor (DPE). It is working fine on DPE and I want to burst the same pattern using a Labview vi.
I tried using the BurstPattern.vi example given but have gotten the error saying 'Invalid Label name: TempSensor'
I've exported the digital pattern from DPE, so I'm not too sure what is wrong
Is there any documentation or videos where I can learn about bursting patterns using labview because I could not find any relevant
Inputs into burst pattern block
Burst Pattern
Thank you
(938 Views)
Hi all,
I figured out my problem
The pattern name was incorrect
I was confused and thought niDigital Burst Pattern.vi called the TempSensor.digipat file
i.e. the pattern name should have been called TempSensor
(883 Views)
