How to build applications for a target that runs windows embedded standard in LabVIEW 2013?
How to build applications for a target that runs windows embedded standard in LabVIEW 2013 on Windows 7 computer?
(2,488 Views)
Shijie,
You will have to add a target to your LabVIEW project. Then you run the VI from the host computer and the VI will compile and run on the target. You can also connect the target to a monitor to view the front panel of the VI. Please take a look at the following document.
Working with Windows Embedded Standard Targets - LabVIEW Help
https://www.ni.com/docs/en-US/bundle/labview/page/working-with-windows-embedded-standard-targets.htm...
Warm Regards,
William Fernandez
Applications Engineering
(2,455 Views)
