How to build a simple array
Hellow! can one has an idea on how to build a simple array like:
0,10,20,30,40.......
thanks!
(3,179 Views)
You can use a For Loop and multiply the iteration terminal by 10, then wire the result to the border of the For Loop. This will generate an array that contains all the multiples of 10. You can wire the N terminal of the For Loop to indicate how many values you want to generate.
Hope this helps,
-D
(3,179 Views)
Here's an example of what Darren suggested. I've saved it in 6.1 so it should work in any version 6.1 or later.
Ryan K.
(3,179 Views)
