How to build a inverse matrix
I have a matrix (A). How to build the inverse matrix (A)? I am using labview 8.6
Khanh
Message 1 of 13
(5,003 Views)
Use inverse matrix, I believe this is available in 8.6 too. http://zone.ni.com/reference/en-XX/help/371361G-01/gmath/inverse_matrix/
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 13
(4,990 Views)
Hi KPRO,
that's the LV2009 style:
See the attached VI in LV8.6…
Edit: Here's the link into the LV8.6 help!
Message 3 of 13
(4,988 Views)
Simple stuff like this is usually much more quickly answered by looking at the LabVIEW help.
Help->type 'inverse matrix'
Message 4 of 13
(4,967 Views)
Thank you very much. It's working now.
Message 5 of 13
(4,932 Views)
Hi
Is it possible to use Linear Algebra functions in cRIO? while the cRIO is Linux based platform and it wont support dlls.
Thanks & Regards,
Shree
Message 6 of 13
(4,546 Views)
Hi Shree,
yes.
LabVIEW will tell you about unsupported function in two ways:
- you cannot find a function in the palettes when it is not supported
- the (RTEXE) build fails with an error message about unsupported functions
Message 7 of 13
(4,543 Views)
Hi GerdW,
thanks for the info. I tried to run a matrix function (Refer attached vi) in cRIO & Win10, the answers are different. When I run the Vi in PC, the output is TRUE and in cRIO, the output is FALSE. So, I gone through the sub vi's, i found there are different DLL functions for PC, RT target. I tried removing the Conditional diagram, but still getting the same result.
Is it any other way to replicate the same functionality as PC for RT target?
Whether cRIO supports DLL call functions? Because cRIO is Linux platform.
Thanks & Regards,
Shree
Message 8 of 13
(4,530 Views)
Replace the  "equal" with a "subtract" and add an array indicator to see how much it differs from zero. Maybe it's insignificant. Comparing DBLs is always problematic.
Message 9 of 13
(4,527 Views)
I tried Subtract to find the difference. The difference is really high. I have attached the screenshot of it. I think the problem is with the DLL. Whether i can replicate the functionality AX = Y in Mathscript?
Thanks iun advance!
Shree
Message 10 of 13
(4,501 Views)
