How to build a VHF digital radio based on FSK?
Hello everyone. I want to design a VHF radio system based on digital voice (similar to DMR). I want to record the voice in real time through a microphone and modulate it into FSK, and then send the signal through the radio. Finally, the receiver decodes the FSK signal received through the VHF radio. Revert to voice.
I don't know how to implement it, I have attached my code.
By the way, can the encryption function be implemented?
(1,608 Views)
Which devices you are using in your project ?
Look at the following link, where describes the FPGA-Based SDR and Its TR Implementation Using NI-USRP
https://www.intechopen.com/chapters/53537
(1,504 Views)
That's a rather daunting task...
You said "like DMR" but from what I understand DMR does not directly digitize your voice and send it over the air.
DMR uses a proprietary CODEC chip that converts your voice into phonemes and basically tells the receiver what phonemes to play back. No digitized sound is actually sent over the air like a cellular phone or other commercial digital radios.
That's why everyone sounds the same on DMR.
=== Engineer Ambiguously ===
(1,495 Views)
