How to bring the graph on front?
Dear all,
i am using 4-5 graphs on the front panel of my Vi on below the other.
On a button click, i am enlarging a particular graph by increasing its height and width. but when i enlarge it, the extended part hides behind the othere graphs on the panel.
Is there any way to bring that particualr graph to the front?
Ritesh
(3,329 Views)
Hi Ritesh,
you can hide the other graphs. It´s unfortunately not possible to change the Z-order.
Hope it helps.
Mike
(3,326 Views)
You can put the graphs on a Tab control.  One tab for each graph.  Programmatically switch tab is easy.
George Zou
http://www.geocities.com/gzou999
George Zou
(3,299 Views)
HI,
I want to have a look at all the graphs at the same time. But, sometimes i need to see the details of just one graph.
So, showing them in tab really wont work out for me.
I guess i need to use the visible property to hide all the other graphs which i dont wish to see.
Ritesh
(3,285 Views)
Hi Ritesh ,
   Yes you are right , if you want  to see all the properties at the same time and sometimes just want to have only some properties on the front panel you have to use property nodes. Please us know if this resolves your query or is there anything else you are looking for .
Thanks ,
Pranchal
(3,250 Views)
