How to bring mouse cursor to the default button of a dialog, like in windows
Anybody know how to achieve this in LV? Smiley Happy
Please see the attached screenshot.
- Partha ( CLD until Oct 2027 🙂 )
Message 1 of 13
(4,174 Views)
Dear partha,Smiley Happy
1) You can be able to trace out the location of the button
2) You can be able to move the cursor to that location
3) You can be able to automatically generate a click on that button
Use user32.dll to achieve all this. when u use it in CLN(Call Library Node), u can c functions 4 that.
Try and ask if further help needed!!!!!Smiley Surprised
Thanks,Smiley Wink
Mathan
Message 2 of 13
(4,168 Views)
Can you tell me the function name & its prototype?
Message 3 of 13
(4,166 Views)
Message 4 of 13
(4,160 Views)
Your VI does not do what I want to... Smiley Sad
Message 5 of 13
(4,155 Views)
Dear partha,
Initially you have to use getcursorpos function to know where is ur button resides and then use setcursorpos and mouse_event functions as necessary.
[Note: If you use the vi developed by this method and if you use it in a different system with diferent monitor size, then it will be a problem.]
Mathan
Message 6 of 13
(4,145 Views)
Hi partha,
is it a dialog which you show from your program? If yes you can use the function mathan mentioned and set the cursor position.
Mike
Message 7 of 13
(4,138 Views)
Hi Partha,
I made this little VI for you.
greets, Dave
Greets, Dave
Message 8 of 13
(4,133 Views)
Dear daveTW,
Please attach all the subvi's.
Mathan
Message 9 of 13
(4,125 Views)
Hi Mike,
It is the screenshot of the Mouse Settings window in the Control Panel of Windows; not related to my project. Smiley Happy
Hi Dave,
When I tried to open your VI, some sub-VIs are missing; so, I m not able to go thro' your code to understand it. Smiley Sad
Message 10 of 13
(4,123 Views)
