How to better understand the Graphics Example
In the LV examples there is a project titled Graphics Example.  Where do I go to learn more on how this works?  For example, there is an object titled Circle.lvclass.  How does this make a circle?  How do I create one to make a triangle?
I'm using LV 8.6.
Dave
(2,995 Views)
The description of the example is as follows:
"This example demonstrates a traditional hierarchy of classes. The Line, Point, and Collection classes inherit from the Graphic class.
Refer to the LabVIEW Help for more information about LabVIEW object-oriented programming."
So maybe you should start with the LabVIEW help (e.g. with the three sections listed here) 🙂
 You migh also want to read the following article: LabVIEW Object-Oriented Programming: The Decisions Behind the Design
(2,987 Views)
Thank you for the references. Prior to this I did not even know what the subject matter is. Thanks, Dave
(2,936 Views)
