How to avoid thread reusing in parallel programming
No, the VI including the CLFN must be reentrant as well.
Now the most important question from my side:
How do you know that the first iteration does work concurrent whilst the following iterations do not?
I suspect that the "issue" is always present, regardless of the iteration.
Another important thing to note is:
The Desktop Execution Trace Toolkit does NOT show which while loop executes in which thread. To be precise: A single while loop can use several threads.
I have also tested if the CLFN shows up in the trace (was not sure about this), but obviously, it does not display.
So next question:
Why do you think to know which while loop executes in which thread?
Norbert
Norbert
Expert: Geometry
Message 11 of 11
(335 Views)
