How to avoid one single large TDMS file?
Hei
I am testing the constant logging for multichannel cases.
If I log the measurement for more than 1 hour, the file size becomes more than 6.6 G.
My VISTA 32bit system does not support a single file which is more than 4 GB, and I have to use this computer for analysis.
How to avoid generating a single file in the constant logging (TDMS)?
Thanks a million
Message 1 of 15
(4,103 Views)
Hi Guosong,
I would consider this as a very valuable request for TDMS files, but unfortunately we don't have this functionality currently. I'm afraid you have to implement it by yourself. For example, you can record down how much data values you already have written and when it comes to some threashold, you start to write a new TDMS file.
Yongqing Ye
NI R&D
Message 2 of 15
(4,101 Views)
Is there TDMS file splitter?
Message 3 of 15
(4,101 Views)
Try to use the TDMS Defragment VI. For my application I reduced the file size to a 5th.
( What I prefer is to setup logging trigger during the aquisition to log only relevant data. )
Hope it helps
Christian
Message 4 of 15
(4,101 Views)
thanks a lot
I will try it.
In addition, our usages are long term observation in field trials. I am afraid that your advice can not be applied.
Message 5 of 15
(4,099 Views)
If your requirement is for long term like monitoring solution. CITADEL is also a good option.
-HS
Message 6 of 15
(4,097 Views)
I am not used to TDMS files that BIG. Is the 4 GB a limetation of TDMS or your OS. It could perhaps be that you are using FAT32 and not NTFS as your file system
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 15
(4,091 Views)
You are right. My 32 bit system does not support a file more than 4 G, but the system of WIN7 64bit does.
Message 8 of 15
(4,085 Views)
This has nothing to do with 32 bit OS versus 64 bit OS. I am running XP 32 bit. But I have formatted my disk in NTFS fileformat. So larger files than 4 GB is no problem. As implemented, the maximum NTFS file size is 16 TB. If you right-click on the disc icon in explorer and select properties. You may find out what file system you are using. By right-clicking on the disc icon in explorer, then select properties
You can convert a FAT32 disc to NTFS. So you do not have to reformat. I think this is part of the standard windows tools. Since I am not using VISTA. I can not help you. But try Google
Message 9 of 15
(4,081 Views)
My disc format is NTFS, and error happens if I copy the file more than 4G to this computer of VISTA
Message 10 of 15
(4,077 Views)
