How to average every certain lines in a 2D array
For example, if I have a 1000 by 300 2-D array and I want to average every 3 lines in this array to make it a 1000 by 100 array. How can I do this? Thanks!
Message 1 of 10
(4,604 Views)
     Use Delete from array,specify the dimension to it and then average.
Message 2 of 10
(4,601 Views)
Decimate the array into 3 arrays.  You may or may not need to transpose it before that depending on the layout of your rows.  Add the 3 arrays together.  Divide by 3.
Message 3 of 10
(4,599 Views)
Decimate only works for 1D array, so this needs a bit more work. Still, it should not be too difficult. 🙂
Is a "line" a column or a row?
(And no AutoTEX, "delete from array" makes no sense at all for this.)
Message 4 of 10
(4,594 Views)
Sorry I am not familiar with arrays, do I need to use a loop or something like reshape array to make it a 1d array to use the decimate? Thanks!
In  this example,  a "line" is a column.
Message 5 of 10
(4,590 Views)
Hi
Check the attachments
Santhosh M
Message 6 of 10
(4,586 Views)
OK, here's a simple way to do this (LabVIEW 8.0)
Message Edited by altenbach on 11-03-2008 09:05 PM
Message 7 of 10
(4,558 Views)
Santhosh M wrote:
This is extremely inefficient, because the array in the shift register changes constantly, forcing new memory allocations with every iteration. This will be orders of magnitudes slower than a solution that operates in-place.
I would strongly recommend against this solution. 🙂
Message 8 of 10
(4,553 Views)
That's exactly what I was thinking, except I didn't realize the decimate array wouldn't work on the 2-D array, and I wasn't on a LV computer at the time to work up the example.
Message 9 of 10
(4,520 Views)
Thanks very much for all your advices. It works great!
Message 10 of 10
(4,515 Views)
