How to assign WASD keys to Arrow keys (key mapping)?
To increase rate of making source code there is useful to use WASD keys instead arrow keys. It is useful for right-hand users.
(20,828 Views)
Accepted by topic author Segeta
Hello Jiri,
I would recommend you to use external applications for key mapping.
An example: http://www.howtogeek.com/howto/windows-vista/map-any-key-to-any-key-on-windows-xp-vista/
I am sure you can find multiple applications on the web that fit your needs,
Mircea
(20,778 Views)
Hi Mircea.
Thanks, it works fine, even Shift-WASD (move LabVIEW objects by bigger step) works.
But I have to find out solution to change reigistry values only for LabVIEW, even for non-type mode.
Or download other non-registry key mapping application.
Jiri
(20,767 Views)
