How to assign Array Values to names in a new Cluster/Array
Hi everyone,
I'm very new to Labview and searching for a possibility to solve my Issue.
I have an array (1D) with different hex values (1,3,1F,....),which varies from 34 to 100 parameters each time. I'd like to give every value a name (for instance 1=Apple, 3=Cucumber, 1F=Tomato) and put all the Informations in a new Cluster or another Array.
What would be the easiest way to do this? I attached a picture to make it easier to understand.
Thanks in advance for your help!
(4,263 Views)
Accepted by topic author Kahlua85
Hi Kahlua,
create a cluster containing two array: your Array1 (values) and Array2 (with their labels). For each element in Array1 you put the corresponding label into Array2…
Or do you want to create key-value-pairs? Use variant attributes
(4,246 Views)
thank you i think that will do it!
(4,240 Views)
