How to append and sort 2D array?
Dear all,
I have six 2D arrays, every 2D array conresponding X and Y value, Now I want to append these six 2D arrays together, and then reorder them by the increasing order of X value.
I try to use "build array" to append them, but it looks only can use for 1D array, so how can I append these six 2D arrays? is it the block "Insert into array"?
and after that how to recorder the whole 2D arrays? I only found "sort 1D array", but how to sort 2D array?
Thank you for any help!
Jing
Message 1 of 19
(6,236 Views)
Hi
Build array is the correct function to use if you want to append arrays. You might have to right-click the build array block and activate "Concatenate Inputs", else the output will be 3D.
Sorting only works for 1D arrays, you can for instance create an array of clusters with x and y values (x must be the first element in the cluster if you want to sort by x) and sort this.
Hope this helps,
Daniel
Message 2 of 19
(6,230 Views)
Hi jing,
see the attached example. First i create two 2d array, then i build a new one and then i sort them.
Mike
Message 3 of 19
(6,229 Views)
Thank you Daniel for quickly answer! It is very helpful, Thank  you again!
Jing
帖子被菁菁在06-03-2008 03:42 AM时编辑过了
Message 4 of 19
(6,222 Views)
Thank you Mike for your quickly solusion!
 and If I want to append six 2D arrays just to large the input of " build array" to six, right? like attached picture.
BTW: you are really early today!!!!!!
Jing
Message 5 of 19
(6,219 Views)
Hi jing,
yes enlarge the "build array" function to six. Notice that it could be that your 2d arrays are transposed!
Mike
Message 6 of 19
(6,217 Views)
Hi jing,
you can also do it in a loop.
Mike
Message 7 of 19
(6,214 Views)
Hi Mike thank you again
Now I met a problem again, after getting the sorted 2D array ( one array corresponding to X and the other corresponding Y value) , then I want to get more accurate Y value for every X value point.
I want to do it in this way, for example:
X value:0   1   2   3   4   5   6   7   8   9
Y value:8   5   4   6   4   7   6   1   3   9
for the X value 5,  I want to add the all Y value corresponding X value before 4 and after 4 point to X value 5, and then divide by 9, then I can get the more accurate Y value corresponding to X value 5. the average value for X value 5 is: (5+4+6+4+7+6+1+3+9)/9
I expect to do this for  every X value point, then I can get more accurate Y value. Do u  have some thoughts?
very apprieciating for your help!
Jing
帖子被菁菁在06-03-2008 06:08 AM时编辑过了
Message 8 of 19
(6,197 Views)
Hi jing,
see the attached picture.
Mike
Message Edited by MikeS81 on 06-03-2008 01:25 PM
Message 9 of 19
(6,191 Views)
You are always so quick!
Good for you Mike!
Jing
Message 10 of 19
(6,186 Views)
