How to align the 2D text in string indicator
I have 2D string array.
And i had to convert to string indicator.When i convert that by using array to spreadsheet all the alignment will run out and the the capital word and small letter word also run out even they have same length of the word.
Have any solution to align the string column by column in the string indicator.
Note:Only use string indicator.
(3,420 Views)
Please show us what your array looks like and what you want the result in the string indicator to look like.  It is somewhat difficult to tell exactly what you want from your description.
Lynn
(3,415 Views)
I need this kind of arrangement no matter how long the lenght of string
And the problem is the small letter a and capital letter A even they have same string length .the alignment also run out.
(3,409 Views)
Use a font for the indicator that is mono-spaced such as Courier.
(3,397 Views)
Thank RavensFan
Have any idea to limit the length of each coloum.
(3,379 Views)
Hi wpg,
look at the string formatting codes and choose something like "%10s"...
(3,369 Views)
