06-16-2021 11:29 AM
Hi all
How to adjust the initial voltage of signal generator from 10V to 0V every step is minus 1V ?
I have attached the labview VI for your attention.
06-16-2021 02:28 PM - edited 06-16-2021 02:30 PM
Hi Stan,
maybe you could send one more "VOLT 0 Vpp" command to your device when starting the VI?
The VI seems rather old with all those stacked sequences and GPIB functions!
I recommend to replace the GPIB by VISA functions. You also should cleanup the VI by removing all sequences and enforce dataflow by error wires.
You should not use the "xls" suffix for the created files: they are simple CSV files…
