How to add a carriage return
Hi
How to add a carriage return after Survey Type, so that the Channel Time will start from column one.
Steve
(3,146 Views)
You could write a line feed to the end of the file after writing the ini portion.
(what is the purpose of concatenate string in the lower left?)
(3,143 Views)
Hi
I am new to the Labview. How could I write a line feed at the end of Section 2?
Steve
(3,129 Views)
Accepted by topic author Shijie
try something like the following draft. (not tested, so modify as needed).
(3,114 Views)
It works. Thank you very much.
Steve
(3,106 Views)
