How to acquire a video from a ip camera using TCP/IP?
I have a ip camera connected to a router and I want to acquire its video using tcp/ip. Could anyone help me?
Thanks in advance,
Celia
(8,598 Views)
If you really want to do it yourself using TCP/IP you will have to read the standard : http://www.machinevisiononline.org/vision-standards-details.cfm?type=5
Another way is to use NI Vision Acquisition Software, it include all the VI you will need to do image acquisition.
More doc :
Acquiring from GigE Vision Cameras with Vision Acquisition Software - Part I
Acquiring from GigE Vision Cameras with Vision Acquisition Software - Part II
Hope this helps
Epictetus
Antoine Chalons
(8,568 Views)
Thanks for your suggestion, but what I had in mind was a solution using the TCP data communication protocols vi´s. Something like Testing Camera 1. vi  in http://forums.ni.com/t5/LabVIEW/TCP-IP-USB-camera/m-p/583154. Is this not possible?
Celia
(8,558 Views)
Sure it's possible. You would need to know the format of the data steam in order to read it and process it correctly.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(8,552 Views)
