How to acquire AI without buffer error
Hi guys
 I have at problem with my application. I am using 3 cDAQ chassis with a lot of different modules – Both AI, AO, DI and DO. Its for a test stand. LabVIEW is going to control the test stand and log numeric data to an excel file. I am having trouble with the AI readings. One of these three things is happening:1. I get a buffer overflow error (200279).2. I get an error that tells me that I am trying to read a value that is not yet available (200279).3. I get the numeric value several seconds late (Big delay). I have done a lot of reading in help files and on this forum. Haven’t been able to solve this problem on my own. I have made at property node that shows me how many available samples there are in the buffer. I can give in values in the “cDAQmx assistant” that I am using so the number of values in the buffer pretty much stays at zero – This solves some of the problem, but I still get problem nr. 3 at some point of time.   After some reading I have acknowleged that the “cDAQmx assistant” is not suitable for this kind of application. Therefore I have tried to use some more basic cDAQmx VI´s. But I am having difficulties getting these to work with more the one physical channel. What I need is:- To bee able to read live (Not delayed) numeric data from the AI modules (NI 9219 and NI 9215).- To bee able to change the update time from the front panel while running.- To bee able to read from 3 cDAQ chassis with 4*9217 and 1*9215 simultaneously. I guess that should bee it. I have put in a small example of the issue. The example is taken from my application VI.  Hope that you guys can help me! Best regards Christian Jensen.
(3,290 Views)
Would be nice if there was actually code to debug Smiley Wink.
Could convert the daq-assistant express vi to code and post a screenshot of the resulting code?
André (CLA, CLED)
(3,276 Views)
Hi guys.
After some reading I have acknowleged that the “cDAQmx assistant” is not suitable for this kind of application. Therefore I have tried to use some more basic cDAQmx VI´s. But I am having difficulties getting these to work with more then one physical channel.
What I need is:
I have put in a small example of the issue. The example is taken from my application VI. Now I have also included some screenshots of the VI.
(3,261 Views)
Could you try this example: \examples\DAQmx\Analog In\Measure Voltage.llb\Acq&Graph Voltage-Int Clk-SW Trig Restarts.vi?
 Replace the IO selection ring with a string control and input "Dev1/ai0,Dev1/ai" where "Dev1" should be replace by your device name.
André (CLA, CLED)
(3,255 Views)
Hi André.
Thanks for your reply.
I have done some experiments with the example VI. I do have some problems.
- Cant get it to sample faster then about 1hz.
- Had to change from "commit" to "Verify" in order to get it to work at all.
- Am not sure what you mean with "Replace the IO selection ring with a string control" but I have instead tried to du at timed boolan.
- How to use more then one AI with this sort of acquisition.
Best regards
Christian.
(3,237 Views)
