How to acquire 1 data point per trigger ?
Dear all, anyone can help me in acquiring 1 data point per trigger? just as a Sample/hold circuit?
I changed the example from Labview "Acquire 1 point digital trig", however, it doesn't work, it says data acquiring is inconsistent with buffer. The program is attached.
and I try to use "AI Sample channels.vi", but there is not trigger input and sampling rate input.
Thank you very much for your help.
Message 1 of 10
(3,851 Views)
Which version of LV are you using?
(1 of the 2 questions that always get asked, fortunately, you got the other one)
~milq
Message 2 of 10
(3,848 Views)
7.1
Thanks.
Message 3 of 10
(3,846 Views)
Anyone can help me? thank you very much!
Message 4 of 10
(3,835 Views)
Does LV 7.1 utilize DAQmx?  If it does, you should be using those blocks.  I think you will find the example finder really helpful, there is probably an example you can use without even editing.
~milq
p.s. if I had LV installed on this computer I would tell you the name of it.
Message 5 of 10
(3,831 Views)
Yes, there is DAQmx, but it doesn't work .  The example "Acq one sample" can not run, and  there is no  hardware trigger in this example too.
Message 6 of 10
(3,825 Views)
There is a good example that can do almost exactly what you want to do.  It is called Acq&Graph Voltage - Int Clk - HW Trig Restarts.vi.  There are only three things you need to change.  Change the triggering VI to trigger off of a digital signal, then change the read VI to read a single channel and single sample and finally, change the Samples per Channel to 2.  I have included screenshots of the VI.
The VI works by setting up a digital start trigger that is retriggerable, so that you can have this trigger start the acquisition over and over.  Once the trigger happens, a sample is acquired, read, and then the hardware waits for another trigger.
Have a great day,
Brian
Message Edited by Brian C on 03-28-2007 01:48 PM
Brian Coalson
Software Engineer
Message 7 of 10
(3,823 Views)
Thank you Brian!
But I can not find the example you mention, is it available in Labview 7.1? Could you attached this example?
 I attached a graph of the available examples in my disk.
I tried several examples, most of the examples are "start" trigger, after start the acqusition, it can run without the tigger.  what I want is every acquisiton waits for the trigger.
Message 8 of 10
(3,810 Views)
Sorry, the examples in my disk is attached
Message 9 of 10
(3,809 Views)
hbin
You might be able to just use your "trigger" as an external sample clock.  That way you get one data point per "trigger"
I think you will find the Cont Acq&Graph Voltage-Ext Clk.vi useful for that purpose.  This will start acquiring when you run the application, acquire 1 sample for each "trigger" and graph it.  Depending on what you want to do with the data, you might want to slow down the loop too.
Best of luck,
~milq
Message 10 of 10
(3,805 Views)
