How to access the test report( excel) after the test through web server?
  In my application I am developing an test system. In that test application after the test completed, the test report in the form of excel sheet will be generated. Now I have to access that report through the webserver. How to access the generated report through webserver.
Thanks in advance
(3,010 Views)
What web server are you talking about? Do you already have one or are you talking about using LabVIEW web services?
If you're using a web server on the same machine, you just need to copy the files into an appropriate folder under the www root directory for the web server. If it's a web server on the internet, you can usually upload files via FTP/SFTP or use a HTTP script to POST the files.
(blog)
(2,982 Views)
