How to access the Custom Data type variable given in Expression edit control To and From LabVIEW
Hello, I would like to know how to access the custom data type variable given in the Espression Edit Control from LabVIEW and vice-versa
Say, the FileGlobals.Reference_Handle (Custom Data Type Variable) contains the
VISA I/O session (Which in turn contains VISA_DeviceName: String, Session: Number),
Channel1: Number and
Channel2: Number
I am expecting the user to give FileGlobals.Reference_Handle as the input at the ExpressionEdit Control in the edit screen of the VI Call.
I would like to know how to get the values of this custom data type to LabVIEW?
Say, if I have the Cluster in LabVIEW like VISA I/O session (Deive Name and Session Number), Channel1 and Channel2
how do i need to set this cluster to the Custom Data type variable in TestStand?
Thanks and Regards
Prakash
(3,477 Views)
TestStand to LabVIEW: i didnt understand what you r trying to achieve. But if you are using references, Use Property nodes and Invoke nodes to achieve what you want in LabVIEW.
 LabVIEW to TestStand: check the image below: You need to click the button next to 'container'. I have used a cluster output in the VI.
Hope this helps
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,420 Views)
Thanks for the information..
I actually wanted to know ,
how to access the TestStand custom data type variable given in Expression Edit control (f(x)) on the LabVIEW Front panel
instead of unbundling the container value and using TS_GetProertyValue.vis individually for all the componenets of that custom data type.
Regards
Prakash
(3,389 Views)
