How to access plot properties at run-time
I am currently using Labview 7.1.1, and I am creating a general plotting and analysis program for deployment at our facility.  I would like the user to be able to access the plot properties dialog box that I can get to when the VI is not running.  This would allow them to change colors, plot types, plot names, etc.  I know that the properties menu item is not available at run-time, but has anyone been able to get around this?  If not, and I need to write a subVI to get there, how can I access the symbols for all of the plot types, point styles, etc, that I would put in the listboxes (I guess that would be the best way to do it??)?
Thanks!
Robert Hoffman
(2,645 Views)
Hello Robert,
enable the plot legend and the user can select colors, line width and so on...
To change plot names: use property nodes, get name from user and set correct plot name (first set property "active plot", then set "plot.name" [or similar, can't use Labview at the moment]).
Nearly all things you can do at development by right-click menus can be done via property nodes at runtime!
(2,635 Views)
GerdW,
I have the user currently able to do that, but I was trying to get away from that for several reasons:
  • I am trying not to limit the number of plots, but I have to limit the legend size to keep the front panel sized properly.  If I do this, I can't have access to all of the plots at once.
  • I would like the user to be able to access plot names, and other functions and not depend on the legend for all the properties.
  • I think it would be more user-friendly to have a plot configuration "utility" where they can access all the properties for the plot.  This could be misconceived on my part, but I think it is worth trying.
I like the layout of the plot properties panel, and if I can mimic that, that would be great.
I could be splitting hairs, but because this program is going to widely deployed, user-friendliness is at the top of my priority list.
Thanks!
Robert
(2,620 Views)
