How to Set a Boolean That Only Changes Its True/False When There is a "true" Input?
A group of numbers is used as my input. Currently I want to set my code as: when the input is greater than a threshold number (4 for example) it will display true, and it will not change to false until another input larger than 4 appears. Our current problem is it will display false if the input is less than the threshold(4) when we want it to remain true.
Please help me, thanks.
Message 1 of 10
(14,406 Views)
Usually what comes first to my mind is not the shortest solution, but anyway, it might give you some idea:
Message 2 of 10
(14,397 Views)
The Inverter and the select functions can be replace by a single xor Smiley Happy
Ben64
Message 3 of 10
(14,371 Views)
Accepted by topic author ChLiu
I should have warned the OP I love Rube-Goldbergs... 😄 Yep, a XOR function should be used there 🙂
Message 4 of 10
(14,367 Views)
Thank you a lot Blokk!! You are so nice:) I'm gonna try this
Message 5 of 10
(14,361 Views)
Instead of XOR I typically use a "not equal". Same difference but less nerdy. 😄
Message 6 of 10
(14,334 Views)
Hmm, i think the Truth table is the same in both cases, no?
edit: ah, i see you edit your post. And yep, the not equal is the same 🙂
Message 7 of 10
(14,329 Views)
Yes, the're the same. I would probably create a subVI as follows. No telephone wires across the loop 😄
(Note that the subVI needs to be reentrant to retain state per instance)
Message 8 of 10
(14,318 Views)
Except knowing that True is "greater than" False adds some nerdiness back in.
Message 9 of 10
(14,302 Views)
... but if somebody says that something is going to be great(er), it might not necessarily be true. 😄
Message 10 of 10
(14,299 Views)
