How to Save a Table Data to Excel File
@RTSLVU wrote:
@crossrulz wrote:
RTSLVU wrote:
You know if you make a text file with a TAB delimiter and give the file a .xls extension it opens in Excel just fine. I do it all the time.
You really should not do that.  It makes Excel do extra work.   But Excel can open up *.txt files just fine.  So I save my tab delimited text files with an extention of txt and then edit them with Excel.
Yes, but you have to go through the "import"  process every time and tell Excel the file is tab delimited, that's a P.I.T.A.
And it confuses my managers if I send them a raw data file that will not open directly in Excel by double clicking on it, as double clicking a txt file opens in Notepad by default.
Putting a .xls opens it right up in Excel, but Excel 2010 and newer will say it's not really an Excel file but allow you to open it anyway.
Right or wrong I find it is eaiser for everyone if I do that.
If you save it as a CSV file (comma delimited, .csv file extension), then it will open directly in Excel without going through the "import" process.
Though I guess commas my not be appropriate in all parts of the world as commas are used as the decimal separator in same places.
Message 11 of 20
(3,825 Views)
Actually that is not always true.
We also use Agilent Benchlink software with our Agilent 34970A's and it exports a .CSV file
But since MS Office 2007 Excel has been unable to open these CSV files directly by double clicking on them even though they are associated with Excel.
Double clicking on them makes you go through the import process, and the import process defaults to TAB delimited so if you are not paying attention you end up importing it wrong. (again confusing managers and anoying engineers)
Intrestingly enough if you start Excel and then use the File-Open dialog it opens them just fine.
=== Engineer Ambiguously ===
Message 12 of 20
(3,816 Views)
Double clicking on them makes you go through the import process, and the import process defaults to TAB delimited so if you are not paying attention you end up importing it wrong. (again confusing managers and even some engineers)
Interesting. I use LabVIEW to create .csv files, and with both Excel 2010 and 2013 (not sure about Excel 2007, I no longer have it) I can just double-click on the .csv file and it opens in Excel without going through the import process.
Not sure if there's something different about the Agilent .csv file which would cause the different behaviour in Excel.
Message 13 of 20
(3,811 Views)
I just went back and looked, the problem with opening the CSV files from the Agilent software started with Excel/Office 2003.
I tracked it down to the Agilent was exporting text in Unicode and it needs to be in ASCII for Excel to recognise it properly.
The confusion this caused made us move away from .CSV files and using TAB delimited text files with a .XLS extension.
Like I said before right or wrong it eliminated a lot of headaches for the end user so I will continue to do this and recommend it to others.
Message 14 of 20
(3,801 Views)
One more thing, I have the Office/Excel tool kit in my LabView, there are a couple reason's we do not use it.
  1. It requires Excel to be installed on the target machine.
  2. It uses ActiveX calls to work Excel
Our company refuses to install Excel on "test machines". Only desktop user workstations get MS Office installed as they have to pay for each installation. Our test machines get Open Office installed on them.
I have had problems with LabView using ActiveX usually some strange error that even NI can not figure out due to difference's in the development system and target system.
Message 15 of 20
(3,793 Views)
Thank you all For your Help.. I was satisfied..
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 16 of 20
(3,762 Views)
The Write Measurements file option mentioned earlier doesn't use ActiveX or Excel to make XLSX files, and neither does XLR8.  If your managers want Excel files, then your managers want Excel.  Ignorance on their part shouldn't drive design on your part.
Message 17 of 20
(3,750 Views)
I understand the Write Measurement file option, that is what I used to use until I wrote a vi to write data to files exactly how I want.
Hooovahh wrote:XLR8.  If your managers want Excel files, then your managers want Excel.  Ignorance on their part shouldn't drive design on your part.
Yeah in a perfect world you are right, but in a corporate bureaucracy you do what you have to do to get your job done.
Message 18 of 20
(3,746 Views)
Yeah and some times that means telling the boss you are the expert, and know what is needed to do the task right.  But then again you don't want to be the guy that's not being a team player, not that that bothers me.
Message 19 of 20
(3,728 Views)
Been there done that. Told my manager we need Excel on all the computers, made the request to IT, the IT manager came back with "No, due to the cost of MS Office it is now corporate policy that only user assigned desktops get MS Office. We will install Open Office on all lab and test computers".
They will not budge in this even if we offer to pay for each copy with our budget.
Message 20 of 20
(3,723 Views)
