How to Read the Image in SQL server
I want to read the image from SQL server using labview.In our project languages used are JAVA and Labview
Through java we acquiring the image and write in to SQL Server.
Through Labview I want to read the image form SQL server and i will do some image processing for my application.
My problem when I seen the database the images shown like hex decimal value.
I want to convert the hexadecimal value to image or any other functions is there to directly read the image from SQL server.
Can anybody help me....
Message 1 of 12
(6,550 Views)
A slightly older thread, but I need help with the same thing:
I'm also trying to convert hexadecimal value (from a "image" column) retrived from a SQL-server.
Anyone that knows how to convert a hexadecimal value, hopefully without the need of "Vision Development Module", into an image and then display this in LabVIEW? 😊
Here is an example of a hexadecimal value, of a small "pdf"-icon, retrieved from SQL (using "Database Connectivity toolkit"):
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
________________________________________________
"Science is about knowing, while engineering is about doing"
Message 2 of 12
(5,697 Views)
It is simply a PNG image.  There is the PNG Data to LVImage.vi that could do the job, but it is terrible at dealing with alpha channels.  You will have better results saving to a temporary file and then loading it using the usual picture format subVI
Message 3 of 12
(5,689 Views)
Thank you for your reply.
I have tried to follow your example, both with the use of "Write to Binary File" and the "PNG Dato to LV Image" VI, and they lead to the error:
"LabVIEW: (Hex 0x6) Generic file I/O error" and "LabVIEW: (Hex 0x52) Unknown format specifier" respectively.
Here is a snip of the front panel and block diagram:
Message 4 of 12
(5,674 Views)
The string I was using is raw data with hex display, you have an ascii representation of hexadecimal values.  If this is the case, you need to convert this to raw data
I use Search and Replace to add a tab after every 2 hex digits (skipping 0x), read this new string into an array of bytes and convert the byte array to a string (optional, you can stuff the byte array straight to write to binary file.  I am just cutting and pasting code I have around).
Message 5 of 12
(5,664 Views)
Thanks again for your reply.
The problem is indeed related to the "conversion" regarding hexadecimal values, which I unfortunately do not have much knowledge about....
I tried to follow your example and it looks like the conversion part is not working as intended...
Not sure what I did wrong 😑:
Message 6 of 12
(5,655 Views)
Right click Search & Replace and choose to use Regular Expressions
Message 7 of 12
(5,648 Views)
I have now tried to set/use "Regular Expressions" and the output string (trimmed string) is now different/changed 🤔.
But I still get an error message (no image). So there must still be something missing/wrong (see attached VI) 😑.
Message 8 of 12
(5,627 Views)
The replace string constant needs to be set to '\' code display.  '\t' is a tab character in that case.  When you change it, it will add a \, make sure to remove it.
The code I posted is a snippet, can you use it?
Message 9 of 12
(5,621 Views)
Now it's working 😁!
Thanks alot for your help.
Message 10 of 12
(5,605 Views)
