How to Read barcode using Gige camera qith vison software
Hi ,
I have a Gige vision camera, I need to use this to read the barcode and save it in a file. Is there a way to read a barcode directly from the camera using labview vison software.Please do let me know if there is a way.
Ankit G
(2,844 Views)
Accepted by topic author AnkitG
Hello AnkitG,
If you open the example finder in Labview, there should be some barcode examples.  They will be located under Toolkits and Modules>>Vision>>Applications.  You should find two examples of how to read barcodes.
David A,
(2,829 Views)
Hi Ankit
I dont know if you have NI's Vision Builder for Automated Inspection, it has a function to do Barcode reading, it is very convenient tool to use with lot of good examples.
Smiley Happy
Kudos are welcomed
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(2,821 Views)
thanks it was very helpful
@David-A wrote:
Hello AnkitG,
David A,
(2,812 Views)
