How to Programmatically Set the limit (max, min input) of a control inside a cluster?
I want to programmatically set the limit (max, min input) of a control inside a cluster. (see attached VI).
The max, min value will be read from a file. The input of the control must be within the range defined by the max and min value.
Can anyone tell me how to do it?
Thanks a lot for your kind help.
Xiaogang
(3,391 Views)
Sorry, I forgot to attach the program.
(3,389 Views)
Accessing the properties of a cluster (or array) is not a trivial operation until you have done it once. It's a two step (at least) process : first, ask for a reference (array of...) to the objects contained in the cluster, then tell LV what kind of object you are adressing.
See the attachment.
Chilly Charly    (aka CC)
(3,387 Views)
CC,
Thanks a lot for your help ^_^
Sincerely,
Xiaogang
(3,357 Views)
