How to Plot Chart in a Desired Speed
Dear Community,
I am currently trying to simulate a pre-recorded signal in LabVIEW. I have successfully plotted the amplitude vs. data points on a chart from the excel file. However, I am having trouble plotting in the speed I want to mimic in real-time. My goal is to plot 1000 data points per second from the excel sheet, however, I'm not sure how to adjust the timing loop to achieve that fast. Also, when I rerun the program, how do I make the x-axis of the chart start from zero again. Thank you in advance!
The files are attached below.
"Read_Signal3.vi" is basically reading data from "20.csv" and plotting the points in a chart.
"20.csv" are the data points recorded with the first column as time and the second column as amplitude to the plot.
(1,675 Views)
Accepted by topic author jackhsu66
  • What a mess!
  • To run at 1000Hz, your wait should be 1ms, not 10ms. (but software timing might not be super deterministic)
  • You can remove the header and get the second column as numeric 1D array before the loop, then just autoindex.
  • You can write an empty array to the chart history property mode to clear the chart.
  • You can show the digital display of the chart, no need for an extra indicator.
  • There is no need to get a subset of higher columns (that don't exist!) later in the run.
  • The first valid row is 1. (Taking the subset starting with 2 drops your first data value. The first array index is zero)
  • Your file is not an excel file, just a delimited text file.
See if the attached can give you some ideas.
(1,658 Views)
Thank you so much for the constructive feedback, very appreciate your time!
My code indeed looked ugly... I really need to spend more time understanding the basics of dealing with arrays.
(1,579 Views)
A small addition to Altenbachs #1, Windows is very bad at keeping timing at sub 3ms periods. If you want to replay in a realistic manner it's probably better to plot 10 points at once in a 10ms loop.
Qestit Systems
Certified-LabVIEW-Developer
(1,554 Views)
