How to Import Unicode File
Hi All,
I am creating a multilingual supported software. I have a problem with the multilingual support part. I exported all strings on my front panel to text file with export strings method then translate that text file from English to Korean. As you know, Korean language includes unicode characters. So that I saved my txt file as Unicode. Lastly I imported that translated unicode file to change language english to korean with import strings file but an error occured. The message said "generic error". So how can I import unicode txt file? Because I can change language English to German by using ansi txt file with the same methods. I am sure that the problem is unicode txt file for import method.What can I do to do that?
Thanks in advance.
Mehmet.
(3,704 Views)
LabVIEW does not support Unicode. Actually, it has limited support, so it's not really "official" support. That said, you should read over this page:
A List of Tips and Tools for using Unicode in LabVIEW
(3,691 Views)
Continued here. Please stick to a single thread
Message Edited by muks on 06-16-2010 07:35 PM
(3,609 Views)
