How to Hold data?
I am using an alarm and I send a " true " or " false" sinal to a boolean to represent the alarm. I am comparing each data in an array to a cerntain thredhsold value and if bigger than thredshold then send the true to the boolean, set alarm on. But the samples in the array are aquired very fast, if the first data is bigger than thredshold, a "true" is sent to the alarm, but the second data is less than the thredshold,then a"false" is sent to the alarm, the alarm is off. But what I need is that if the "true" is sent out to the alarm, hold the "true" and keep the alarm on no matter what the next data is. Is there anyway to hold the data?
Thanks in advance,
(3,350 Views)
Add a shift register in your the loop initialized to FALSE. At each loop iteration use a boolean OR between the shift register and the current alarm, then feed the output to the shift register and alarm indicator.
(3,338 Views)
Altenbach has the same solution as I have here. You are just implementing a rising edge trigger, I have attached my "simulator" vi (LV 7.0)
-Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,333 Views)
Thank you very much
(3,332 Views)
