How to Enable Web Application Server for Target Device .
Hi guys
Any idea how to enable the Web Application server for any Target Devices OR particulalry for Raspberry Pi ?
Please have a look on the attched Pciture and advise .
(4,109 Views)
Hi SEMAK,
Steps to enabling a web application server for a target device can be found on this web page:
https://www.ni.com/docs/en-US/bundle/labview/page/setting-up-the-application-web-server-for-web-serv...
(4,068 Views)
Thanks rleonard3 , I've came across before uploading this thread there is somethingwrong i think as i am unable to do so .
Probably its something restricted by the admin as i dont have admin rights .
Probably will finds it solution soon 🙂
(4,050 Views)
 Is the raspberry pi connected to a network server?
(4,036 Views)
Yes  It is connected through WIFI .
(4,033 Views)
At what point are you running into issues with permissions when setting up your web server?
(4,020 Views)
Hi Semak,
I have same problem and I cannot find to start Web Application Server on Target Device RPi3. Did you find any solution for this problem.
Thanks with kind regards.
(3,937 Views)
