How to Create An Arrow Indicator that Fills
I'm trying to create an Arrow indicator that can fill.  I've taken a slide indicator put some flat decoration shapes over it to make is look like an arrow. This works, but I have to created one for each direction UP, DN, Left, Right, for I can figure out how to rotate it.
(2,731 Views)
You already gave the solution yourself:
JordanJ wrote:
...but I have to created one for each direction UP, DN, Left, Right, for I can figure out how to rotate it.
Yes! You have to create one for each direction 😄
Of course you could also use a picture indicator and just draw what needs to be drawn. You could also customize some classic controls. It's not quite the same, because the arrow tips move now. See attached examples.
(2,719 Views)
