09-21-2009 04:24 AM
Build a VI that generates a random number between 1 and 80
Divides the random number by a number specified in the front panel.
If the inputted number is zero, the VI program should turn on a LED in the front-panel to indicate a divide by zero error.
Solved! Go to Solution.
09-21-2009 04:27 AM
09-21-2009 04:29 AM
09-21-2009 04:34 AM - edited 09-21-2009 04:40 AM
09-21-2009 04:36 AM
09-21-2009 05:33 AM
Hai edwardty2009,
Welcome to the forum.
Thanks for the kudos.
Is your problem solved? If so can you please mark as solution which post helps best to solve your problem.
Mathan
09-21-2009 07:04 AM
One quick question Edward, was the answer just in time for your monday morning class.
Ton
