How sort array without using Sort 1d Array?
Oh man, that stop logic! There is no reason to use local variables (and certainly no reason to make the "True" case wire a "True" constant). I can try out your VI but it's going to cost you, you're going to have to upload the the actual VI and not a screenshot.
Message 11 of 22
(5,240 Views)
Maybe you are right.
Message 12 of 22
(5,233 Views)
Just looking at it for 1 second: Your VI is still full of race conditions. There is no guarantee that the local variable in the upper ight gets read only after the same local variable gets written in the case below, but the outcome critically depends on the order. Use dataflow!
(I have not looked at the overall algorithm yet.)
Message 13 of 22
(5,217 Views)
Hi Cris,
It works for me 1000 times out of 1000! You will have to add the input array and output array to the top left and right terminals respectively to run this snippet.
Message 14 of 22
(5,192 Views)
What is "it" that works?
Message 15 of 22
(5,186 Views)
I'm referring to zad1d.vi in message 12. It appears to give the same output as the native 1D sort function.
Message 16 of 22
(5,184 Views)
Sorry, posting from mobile, cannot see message numbers. If it works now, we are lucky that the compiler decided on a good order of operations. This could change whenever seemingly benign changes are made to the code, causing a recompile, or the VI upgraded or downgraded to a different version.
Even if both orders give a good result, it is a glaring programming error that teaches bad habits that can bite us in the future.
Message 17 of 22
(5,168 Views)
Hi gregoryj,
because a VI with known race conditions will work in your example case (computer, CPU, dataset, compiler options, OS, moon phase, many more) it will work always as expected?
What's the problem to remove race conditons and clean up such a small VI?
Atleast the OP should have done this…
Message 18 of 22
(5,145 Views)
Here is version that fixes the race conditions, and also uses the inplace element structure and swap functions to simplify the array manipulation code.
Message 19 of 22
(5,129 Views)
Hi GerdW,
I made no such claim
And I fully expect a waning moon to throw it off Smiley Very Happy
Message 20 of 22
(5,127 Views)
