How should i solve this error code 63040 ?
Hi all
 Now i m uncountering this problem ... please advise me something about this . Thanks a lot .
 With regards ,
roxy
(3,763 Views)
search will help you. Else post in detail about what device you are using? why you got that error? What you have done till now?
Mathan
(3,760 Views)
hi
I using cRIO 9012 and NI 9233 .When i everytime run the same error will appear .I dont
know whats the reson.As u say earlier i go through discussions fomrs but one thing i dont
understand is how to reformatting cRIO 9012? Can u suggest me some idea?
with respect
roxy
(3,757 Views)
Hi Roxy,
              R u defining the proper IP address?
Check this
(3,739 Views)
yah. Its same IP address in my project and MAX .
ERROR: -63040
NI-RIO FPGA Communications Framework: (Hex 0xFFFF09C0) A connection could not be established to the cspecified remote device. Ensure the device is on and accessible via the network and that it is listening on the correct port."
Can u suggest me how do i fix it?
thank u for ur time
roxy
(3,735 Views)
Did you check the hyperlink?
Message Edited by muks on 08-08-2008 04:10 AM
(3,733 Views)
Hi Roxy,
Below are a couple of resources that explain the error you are receiving and how to correct them.
Knowledgebase 1
Knowledgebase 2
I hope these resources are of some assistance, let me know how you get on.
Mike W
National Instruments UK&Ireland
(3,729 Views)
