How should I fixed the error code 200357?
I am the beginer and  would like to do strain measurement with strain gauge. I have NI cDAQ 9172 chassis with NI 9237 DAQ. I have followed the construction for strain measurement mentioned at below NI web-page. However, during tesing signal, I click run, and I got error code message 200357.
http://www.ni.com/tutorial/7130/en/
I think my proble is related to input parameters: I know gage factor and gage resistance for my gauge, but don't know how or where to get the rest parameters: Initial Voltage, VEX Source, VEX Value (V), Lead Resistance.
Second question: Could I used MyVirtualStrain for data acquisision, or it is only for signal testing and for real strain measurement I have o go to LabVIEW Example for Measuring Strain (Figure 7 at above home page).
Thanks in advance for your support
Hassan
(3,334 Views)
Hi Hassan,
Does the error code provide any additional information besides the number?
Are you receiving this error in MAX Test Panels and in LabVIEW?
Is MyVirtualStrain the name of a strain task that you created? If so, you can access any tasks that are created in MAX in your LabVIEW program, however you can also create a new task in LabVIEW.
What do you mean by "real strain measurements"? Are the values that are being measured when you receive the error not the real measurements?
Regards
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
(3,291 Views)
