How save data step by step into the same file ?
Hi, sir,
I am doing the following job:
I set a current value on a window and get a value corresponding with this current value, then I hope to save the two values into a file. Then I set a second current value on the same window above and get a second value corresponding with the second current value, then I hope to save these two values into the same file above. .... I hope to do such steps many times. How can I do that ? I am using Labview 6.0, and can you give me an example ?
Thanks a lot.
(2,793 Views)
"create and append data to file"
jus a clue for you
regards
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,793 Views)
Thank you very much, and I solved this problem by using your clues.
(2,793 Views)
My pleasure 🙂
labview@ianfung.net
Ian F
依恩与LabVIEW
(2,793 Views)
