How pass subarray to string?
Hi, I need pass of subarray to string, someone can tell me how do it?
Message 1 of 10
(7,567 Views)
Array to Spreadsheet String
Or
Concatenate
Message 2 of 10
(7,562 Views)
As much as I understabd, you want to convert a string into string? You have an array composed of strings. You take one element from that array as a subarray. But it still is a string. So what conversion do you need?
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
Message 3 of 10
(7,559 Views)
It's not at all clear what you're asking.  Could you please explain in more detail exactly what you're trying to do?
Also, you have an infinite loop which takes up 100% of your CPU.  Add a small time delay inside your loop, and replace the "F" constant which is wired to your loop's terminal with a "stop" button.
Message 4 of 10
(7,558 Views)
Probably Ravens Fan has guessed it right. Yet it is sometimes really a challenge to understand what the person is trying to say 🙂
Message 5 of 10
(7,555 Views)
Hi WSalas,
Looking into your VI I understand that you want to select one name from that list (that is an array) using the index control and want to show in an indicator. But you don't want that indicator as an array. You want only a simple string indicator showing the selected name.
If this is the case, the simplest way is to change the function Array Subset that you used and replace by an index array function. You can find this function in the array pallette.
I hope this helps.
Rodrigo Schneiater
NI Brazil
If this information was useful, please click in the 'KUDOS!' beside.
Message 6 of 10
(7,514 Views)
DianeS wrote:
Also, you have an infinite loop which [...]
I heard that Windows 8 will be able to execute an infinite loop in just under 300 ms!
Jim
Message 7 of 10
(7,510 Views)
Hi Schneiater, Thank you..
Message 8 of 10
(7,486 Views)
Infinity has just become finite thanx to Windows 8. Smiley Very Happy
- tbob
Inventor of the WORM Global
Message 9 of 10
(7,439 Views)
Yes, and you know why? Cuz I'm a PC and windows 8 is my idea.
Message 10 of 10
(7,435 Views)
