How insert string into double array???
I would like to know how I can insert a string (date and time) into a double array???
Is it possible???
Thanks for you help!
Cordially!
(4,948 Views)
Hi carlito,
you cannot insert a string in a DBL array...
But you can:
1) convert the time value given by 'Get Date/Time in seconds' to a DBL value and insert this value in your array.
2) convert the DBL array to a string array and insert your date/time string here
There are probably other options, it all depends on your goal!
(4,944 Views)
Hi GerdW,
Thanks for you help. I don't understand your answer. Could you send me a quick example, please???
Cordially,
(4,939 Views)
What you could do is convert the read timestamp to dbl >>insert it to the 2D array, later index that entry and convert it back to Time stamp
Look at attached vi
Dev
(4,935 Views)
Hi karlito,
here is the example you requested. It's in LV7.1.
(4,932 Views)
