03-11-2011 09:24 PM
According to online documents shared variable engine update at 10ms or forced by flushing command. But I tested the following two program and can not get the shared variable updated:
Thanks fo rhelp!
Tom
03-13-2011 03:26 AM
Hi Tom,
What is the reason you're using shared variables?
03-13-2011 10:27 PM
I used shared variable to transfer data between RT to host.
Tom
03-14-2011 09:07 AM - edited 03-14-2011 09:08 AM
What is your application? Why would you need to transfer NSV data from the RT to the PC so quickly? If you need to capture a exact transcript of your RT waveforms (guaranteed not to drop any data points) then NSV's are not the best solution. Use Network Streams or roll your own TCPIP transfer vi's.
03-14-2011 09:17 AM
I don' use NSV to transfer large amount of data between RT and host. The actual application is as follows:
I also would like to test how fast the NSV update rate and how the flush vi works. I test two programs and did not match the number in the documents.
Tom
03-14-2011 08:16 PM - edited 03-14-2011 08:16 PM
Hey Tom,
I just wanted to know what kind of system you were working on. I.E. What version of LabVIEW you were using, what Operating System, etc....
Jake
03-15-2011 08:00 AM
Hi Jake,
I used LabVIEW 2010 and Windows 7.
Tom
03-15-2011 10:43 AM
Can you post a link to the documents that you are using to get these numbers?
03-15-2011 11:57 AM
03-15-2011 11:59 AM
I forgot it has to be both directions. So delay longer than 20ms works.
Tom
