How does labview implement this progress bar function that comes with windows?
007.pngHow does labview implement this progress bar function that comes with windows?
Message 1 of 13
(2,866 Views)
Hi WhiteSpace,
I would use a waveform graph, with a cursor to show the average line with its label.
What have you tried so far?
Message 2 of 13
(2,863 Views)
Could you write a demo to learn from
Message 3 of 13
(2,856 Views)
Hi WhiteSpace,
Open the ExampleFinder and learn from "Graph Cursors" example VI…
(LabVIEW comes with a huge list of "demo" examples!)
Message 4 of 13
(2,834 Views)
Here's a quick draft that you can modify according to your needs.
Message 5 of 13
(2,777 Views)
Here it is as an XControl
Message 6 of 13
(2,703 Views)
An alternative to replicating the Windows progress dialog box in LabVIEW is to have Windows show it.
This can be done using the Call Library Function node to call the Shell32.dll SHFileOperation function, albeit LabVIEW can't provide much automatic assistance creating the parameter it takes (a pointer to a structure that has, among other members, pointers to strings), but it can be created using the LabVIEW memory manager functions, for example.
It can also be done more simply by using one of the Microsoft.VisualBasic.FileIO.FileSystem .NET methods, such as CopyFile (which calls SHFileOperation under the hood), which I show an example of below that can be played with:
Message 7 of 13
(2,603 Views)
Let's share the DLL file
Message 8 of 13
(2,593 Views)
I take it you're interested in seeing a solution that calls the Shell32.dll SHFileOperation function directly. Below is one of the simplest examples I could create, which will only work in LabVIEW 64-bit (because 32-bit requires 32-bit pointers, albeit hopefully this example can be generalised from).
To be able to understand the example and build upon it requires understand the following documentation for the SHFileOperation function, which is what I used to create the example: SHFileOperationA function (shellapi.h) - Win32 apps | Microsoft Learn. Also, I used Visual Studio to see the memory layout of the SHFILEOPSTRUCTA structure and determine appropriate member values.
This is more complex than using the .NET methods I mentioned in my previous post but has the benefit of offering more capabilities.
Message 9 of 13
(2,579 Views)
Could you share the source file VI
Message 10 of 13
(2,571 Views)
